Old 07-05-2009, 07:15 PM   #2
vath2001
Originally Posted by sullivan_pbr
well, i've done some searching and haven't had any luck finding any answers to my problem. i have a 99 boxster and can't lock it. the switch on the dash will lock it, but when i insert the key in the door and turn it nothing happens. my keyless entry does not work either(hasn't since i've owned the car) so i can't lock it that way either. I'm assuming when you turn the key it operates some sort of switch inside the door. i'm guessing this switch has gone bad, but i can not find a part number for it. does anyone know if this might be the problem? if so where could i get this online? i'm trying to avoid going to the dealership, it is over 3 hours away and i am currently unemployed so money is tight. any help would be great. thanks guys.
Sounds like the guts of the door lock "failed" It cost me $800 at the dealer.
Good Luck
My Porsche mechanic drives a Saturn.
'98 Artic Silver w/ Tip
vath2001 is offline   Reply With Quote
