Thread: Rebuild Tranny
Old 07-04-2009, 07:42 PM   #3
Viper5
So what you're saying is that I won't be able to remove the gears from the box since it takes 10,000 lb to do so? That sounds like a lot. About 3 times the weight of the car in fact. You say it's the pinion bearings (I'm not even sure what those are) but I've been told by numerous people (including on this forum) that it is most likely a synchro issue. All I think I need is that synchro, but I was going to get them all replaced along with the clutch in the process. Thats what I understand the 3k to cover. Does this sound like a reasonable price? What about the pinion bearings that you mention and all the other parts. Is it worth just replacing everything?
Viper5 is offline   Reply With Quote
