Old 06-30-2009, 10:02 AM   #11
RandallNeighbour
Originally Posted by bmussatti
Randall, the neddle on my temp gauge is always in the exact same spot (when up to temp) since brand new.
That explains a lot. Bill, the 987's no longer have a real temp gauge. It will rise to the right spot before the motor is truly up to temp and only climb when the computer says it should so you will pull over and get the motor looked at. It's now like the crappy ones found in American cars. If the car's not overheating, that needle in your 987 will not show any fluctuation at all.
Mark and I have checked this out on his 987 at the track when he's been absolutely brutal to the motor on the track and that needle should have moved a little and it does not move past the operating temp reading it is programmed to display.
The 986's have a temp gauge that moves around when you drive the car, hence all the guys freaking out because they've never owned a car with a fully operational temp gauge before.
