Old 06-28-2009, 04:58 PM   #1
Boxtaboy
07 Carrera S Cab
Boxtaboy's Avatar
Originally Posted by boxstermike
Do you have to pull that pull fuse all the way out? Maybe I am not getting good ground. What is the best grounding spot
I don't think you have to pull the fuse out. If I recall correctly, I saw someone use the door latch strike plate as the ground.
