Old 06-26-2009, 02:08 PM   #13
dja1980
Originally Posted by ekam
There's a rubber seal on the inside to protect water from going in to the circuit board.
Mine used to have the rubber seal, but it started to get very loose, so I removed it. It was causing the top of the key head to pop up in the front.
At first, I thought it was the key ring putting to much pressure toward the back of the key head... but problem fixed since I removed the rubber seal. Now I just have to keep it dry!
dja1980 is offline   Reply With Quote
