Old 06-24-2009, 03:25 PM   #23
Thumper
Thumper's Avatar
I am really surprised the RUF said it wouldn't work due to them being different part numbers. I have put 5 different clusters from 986's and 996's in mine from years '01 thru '03 and all but one worked great. (one cluster was just fried). All had different part numbers.
I have also talked with a couple of guys that have swapped various gauges from one cluster to another and had them work fine as well. It would be worth a try to swap the gauges in order to make one good cluster out of the two.
I have a perfect 986 cluster (black faces) sitting in my garage if you can't find one. The mileage is in the 60k range. But it is from an '01 and I'm not sure if you can go with something from a non CAN BUS system or not.
Thumper is offline   Reply With Quote
