Old 06-24-2009, 03:18 PM   #22
fredpayne
fredpayne's Avatar
Thanks's Thumper
I'm glad I waited to hear from you, RUF and Boardwalk both told me it would not work, they said they were 2 different part numbers, which they are, but they look the same, I took the day off today to try and solve this problem. After I talked to RUF and Boardwalk, I called Fifth Gear in Lewisville, I know them pretty well too, they had no idea, but I was told if the Part numbers didn't match it wouldn't work.
I was told the cluster was basically a computer and had to match, Boardwalk said once the cluster had been programmed, it usually would not take another program.
I have one cluster where everything works except the Speedo, and anothe cluster where everything works except the tach, I currently hvae 2 sources looking for an S cluster, I will call them off and try to get one of these repaired, Zepco didn't know much about Porsches, so I guess it's off to California for repair, too bad I can't take the speedo off the one working and put it on the other one.
Where you at the last Sunday Drive? It was the bridges of Denton County or something like that, I was in the one and only Orient Red Porsche there.
fredpayne is offline   Reply With Quote
