Thread: Clutch Corner
Old 06-24-2009, 10:02 AM   #2
eightsandaces
Originally Posted by Boxtaboy
I had my motor mount replaced on my 2001 at 58k miles, and it did help smooth out an annoying 3k rpms vibration I used to have when decelerating, but I never had any chattering in my clutch. The new motor mount had absolutely no effect on my clutch action, and it still feels exactly the same as it did before. I can see how a new mount would improve shift action, but not sure how it would affect your clutch takeup.
I also had a really annoying grinding noise when making turns under power, and the new motor mount fixed that. Apparently, the old mount was so worn that it upset the drivetrain geometry.
Here's a how to on changing the motor mount:
http://www.pedrosgarage.com/Site%203/Install%20Front%20Engine%20Mount.html
Thank you very much, I truly appreciate it. I don't know how to describe it but it's as if you can feel the engine buck, the mount needs replacement, if the clutch does too than so be it, I own my 1998, I need to keep it as nice as I can.
eightsandaces is offline   Reply With Quote
