The high beam and front fog light share a ground with the rest of the lights on the left, so it should not be a ground problem. They are on separate fuses so even if one did go bad it is unlikely you lost two at the same time.
I think your most likely issue is a connector problem (loose/corroded).
2001 Lapis/Black/Black, PSM, Rear Speaker Kit, Optima...
