Old 06-23-2009, 02:32 PM   #5
Aron in Toronto
The leak could also be from the IMS bolts. They are located above (or below, can’t recall) the RMS and are usually replaced when the RMS is replaced as a precaution. Porsche has an updated "encapsulated" bolt(s) that supersedes the original bolts. This is not to be confused with the updated IMS bearing from Raby/flat6.
1997 Boxster
http://i40.tinypic.com/ax1qhz.jpg
Aron in Toronto is offline   Reply With Quote
