Old 06-23-2009, 11:25 AM   #2
JFP in PA
As you probably know, the litronic lights themselves are "plug and play". As far as installing the additional hardware that is needed to activate the rotation of the upper and lower beams is concerned , in my experience the amount of time and labor that was involved was simply not worth it. The end result produced a very minor difference. I would suggest installing the litronics and forget about this other negligible feature.
Actually, all that is required in the installation of a small control unit (about the size of a pack of cigarettes) in the headlight wiring harness; takes about 10 min.
As for the difference it makes, once you have it, you’d never be without it………………..
