Hmmm, I find that extremely interesting, I have disconnected my battery several times and the radio worked fine when I re-connected, I see you are in McKinney, I am in Carrollton, when I get this project finished, hopefully by the weeks end I am taking it to RUF to have a little OBC programming done. So I should be totally finished by next week early, I broke the cam off of the green connector in the back of the cluster, I have a new one with a 6"pigtail of wires hanging out, I just need to match them all up, solder them and use a little heat shrink around each one. When I get all finished maybe we can meet up and have a cold beer.
Originally Posted by Thumper
You need the radio code in order to re-activate your radio once the battery has been reconnected. The code is a security code meant to discourage thieves from stealing your stereo, as it won't work without the code. It's a 4 digit number that should be included in your set of manuals on a separate card, or in my case the card was missing, but the previous owner had written it down on the inside cover of the maintenance manual.
