Old 06-22-2009, 09:02 AM   #10
Thumper
Thumper's Avatar
It's a plug & play proposition. There are two screws that have to be removed to get the entire gauge pod to come out. One behind the microphone cover on the left side and one behind the emergency flasher switch on the right side. The entire gauge pod lifts up and there are three wire harness connectors on the back of the cluster. Each has a locking lever that you raise up and they come off. A few screws (they will be obvious) hold the cluster to the pod. Installation of the replacement cluster is the reverse of what you just did to get the old one out.
Be sure to disconnect the battery before you start taking out the original cluster.
Thumper is offline   Reply With Quote
