Old 06-21-2009, 11:31 PM   #13
2K3_Boxster_S
Originally Posted by cnavarro
I have the full system on my 2.9L. Looks nice, sounds good. Made a difference on my 2.9 over a stock system, but my engine is far from stock. My biggest complaint is that the tube diameter is wrong for using the factory U pieces that you have to use in the install, so it's pretty much impossible to not have exhaust leaks.
so you have NHP Full exhaust installed on your 2.9L and you are saying that it does not bolt up perfectly? If so then, my whole set will be getting returned.
Also specify exact set-up if you have NHP.
example: Headers with sport cats, mid pipes with or without cats, and exhaust.
2003 Boxster S
2K3_Boxster_S is offline   Reply With Quote
