Thread: top stuck up
Old 06-21-2009, 05:50 AM   #2
Boxtaboy
07 Carrera S Cab
Boxtaboy's Avatar
You say the latch microswitch works, so I assume the windows drop when you open the latch, right? If so, and then the top just doesn't go down when you push the button to put it down, maybe the microswitch at the handbrake (under the center console) isn't working. You normally have to pull the handbrake up to activate the switch before the depressing the button will allow the top to move. Try putting the handbrake up and down a few times and see if that works. If it's the microswitch there, you'll have to pull your center console off to replace that switch.
