Originally Posted by TimAustinW
They are pretty easy to remove.
As quoted from the Bentley:
"Remove the screw." If you squat down and look up into the intake vent you'll see one screw on the upper underside.
"Using a plastic pry tool or narrow tipped screw driver, pry back the clips and pull vent from quarter panel."
You should then be able to just push the grill back and out of the brackets.
While you're in there... desnorkle.
Are there any pictures available of these clips? I have a 2003 and have a bees nest in my intake side that I need to remove. I tried yesterday and after removing the screw I could not find (with my fingers) any clips to remove but the vent would not come off and I did not want to break it.
I'd like to desnorkle at the same time but can't figure out where the "clips" are located that I need to pry.
