Old 06-17-2009, 06:57 PM   #3
sb01box
regards to drop links at the four corners.
I visually inspect then and all are straight and appeared OK. I then grabbed the drop link and tried to wiggle it - if worn linkage, would I be able to feel play or do I need to unload the suspension to take out possible preload before I can wiggle them to determin slop?
or what do I need to do to determine if the drop link needs replacing?
thanks in advance
sb01box is offline   Reply With Quote
