Try easing off the throttle when you're in a situation where you want the back end to break loose. Just a little weight transfer forward should be enough to get the rear end loose. I found that I was bulldozing the front tires instead of easing up and letting the back end rotate.
You might also try adding a couple of PSI to the rear tires...
1999 Carrera 4 • Aero kit • 4" UD Pulley
My Corvette doesn't leak oil... it sweats horsepower.
