If you're looking to reduce understeer, you need to increase front end grip. This can be done by reducing front tire pressure, reduce the stiffness of the fromt sway bar or reduce the front spring rate. You could instead reduce rear traction by doing the opposite of what I mentioned above to the rear. 1st thing is to make sure your tires are in good shape and there's nothing loose or broken in your suspension.
