Old 06-16-2009, 01:21 PM   #2
drem914
go for the stack hack
You should go for the 4th stalk hack. It is very simple to add the stalk without taking the steering wheel off. you can usually pick up the fourth stalk from a performance shop or a dismantler. It screws on very easily and running the wiring is simpler than routing to a toggle switch on the center console. I did it and it was easy to do. I believe you may also loose the reset without the second switch. I think it is the same trigger for reset as is the audible on/off.
drem914 is offline   Reply With Quote
