This is weird...I was able to get out to Advance to check the codes and the car drove just fine. Started fine (from cold), didn't miss and didn't stall at stop lights. Anyway, here are the codes and keep in mind I recently replaced the MAF.
0102-Mass Air Flow Sensor - Below Lower Limit
1123-Oxygen Sensing Adaptation Area 1 (Cylinders 1 - 3) - Lean Threshold
1125-Oxygen Sensing Adaptation Area 1 (Cylinders 4 - 6) - Lean Threshold
