Old 06-16-2009, 06:31 AM   #1
pompous
Quick ideas on my box prob...
I have CEL on & about to check the codes soon.
However, on cold starts, it sputters for a couple minutes and then will drive after that. While driving, sometimes it will miss...just kind of cut out for a sec and then be ok. Also, the temp goes up a little past 180. I replaced the MAF probably 6 months ago, but it sounds to me like that's exactly what the problem is. Unless an O2 sensor or even throttle body. What are your guys thoughts? I'm sure i'll know more when I can pull the codes, but my curiosity is getting the better of me.
"You finally got that Nazi-go-cart you always wanted." -Peer
http://i40.tinypic.com/ei6sns.jpg
pompous is offline   Reply With Quote
