Old 06-15-2009, 06:18 AM   #1
Boxtaboy
07 Carrera S Cab
Boxtaboy's Avatar
If the battery is new, what most likely happened was that you did not fully depress the clutch pedal ALL the way down to the bottom when you tried to start the car. There is a clutch switch that j.fro mentioned, which must be fully depressed, in order for you to start the car.
