Originally Posted by cnavarro
That's a good enough list for you to make a decision on an oil if your criteria is to only use approved oils.
Of the approved oils, our recommendation is for Motul 8100 X-Cess 5w40. It carries an API SL rating and has more anti-wear additives and improved HTHS film strength than M1.
+1, Charles, what do you and Jake recommend outside of what's on that list? How does Royal Purple or Redline stack up? I'm thinking of switching from M1, but I'm a bit apprehensive. Are these aftermarket oils really going to make a significant difference in wear ect over M1? I know this topic has been talked about to death on here, but I want your advice.
