Originally Posted by Brad Roberts
The oil from an AOS failure is always behind the throttle plate (the breather line is behind the throttle plate) The only time I see oil up in the MAF housing is when we scatter an engine at 7k+ rpm
I think he has two failures occuring. MAF and AOS
B
my 01 boxster blew out the AOS oil dripped out of the air filter box water drain hole just behind the driver's seat in the engine compartment. about a pint dripped out in 5 minute period with engine off. mine was resolved with replacing only the aos
