Originally Posted by AWay
Nice info regarding the motor mount. I wasn't aware of that. It definitely feels "grindy" going into 2nd and oddly enough 2nd gear has popped out twice now... This isn't sounding good for me. Are either of those two items easily replaceable? The motor mount sounds it, but the synchro does not.
Oh and I ordered the 997 shifter just now as well.
Motor mount is a pretty simple job, especially if you have ramps and a jack.
Syncros, as you guessed, is not a small job. Porsche used to replace transmissions, they now rebuild, I think. there are other companies that now rebuild our transmissions too. You can get different gear ratios and they probably upgrade the syncros too.
http://www.****************************************.com/ShowItem/208345%20Porsche%20Boxster%20Rebuilt%20Transmissio n.aspx
http://www.motormeister.com/suz/trans/clutch_trans.htm
Hopefully the new shifter takes care of your issue.
