Old 06-12-2009, 05:28 AM   #1
Shelly
Originally Posted by Lucky
Definitely change it just prior to storage. Always, always do this. The acids, moisture, and contaminents that build up in oil during use are not good for a stored engine. Your dealer either isn't giving you good advise or isn't taking the time to understand what you are asking.
Listen to the manual, at least moreso than your dealer. I do think the manual's break in guidance is overly conservative and once you get to 1600 km's, you will be fine enjoying the full rpm range, or at least up your limit to 5500 as you finish out the official break in period.
Yes... never lug these engines. High load below 2500 rpm isn't good. You will be doing your engine (and your wallet) a big favor if you stay above 3000 and don't shift until you are at or above 4000 (so revs won't drop much below 3000 with the next gear).
Enjoy your car!
Thanks very much for your reply .
Shelly is offline   Reply With Quote
