Originally Posted by 70Sixter
I recommend you change oil and filter twice as often as Porsche recommends. Use best quality oil you can get/afford.
Change brake fluid every two years at least. Porsche recommends.
More if you track.
Lucky is right - don't worry excessively. Most cars do not have these problems.
And WELCOME!!!
I'm new here. I just purchased an 08 Boxster (new, with 30 km on it). It's my DD for the summer months (I live in Calgary, Alberta) and then it will be stored for the winter. By the time I store it I will probably have 6 - 7k km on it. I suggested to my dealer that I should probably get an oil change prior to storage but his answer was no, maybe when it comes out of storage next spring but probably not even then. Since the car basically sat on their lot for a year, that would be 2 years (or more) before a first oil change. Thoughts? Maybe I should just ignore his advice and get one done at the end of this summer. But if it's really not necessary, I also (obviously
) don't want to spend the money.
My next questions relate to RPM. My dealer, who is a reputable dealer, told me that I don't need to break in the engine. However, the manual states that there is a break-in period for the first 3,000 km during which the RPM shouldn't exceed 4,200 and lugging the motor is really bad. My bet is to go with what the manual is saying (although it's taking some of the fun away since I still have 1,800 km to go!).
And finally shifting. I watch the RPM and try to keep the car in the 2,500 - 3,000 RPM range while driving and probably in the 3,300 to 4,000 RPM to shift (up or down). Is this reasonable? What would you recommend? The last thing I want to do is lug the motor (during or after the break-in period).
