Old 06-10-2009, 07:48 AM   #10
Brad Roberts
Brad Roberts's Avatar
Dump the Porterfields like a bad habit and stay away from the Hawks. The Porterfields work GREAT on lightweight cars, not our 3200lb turds. I use the R4's in a lot of cars with NO ABS and under 1800lbs.
Pagid. Black or Orange.
and a tibit: if the pads you are running are UNDER 5mm's on thickness.. toss them out or keep them for an emergency backup. The pads partially relies on "thickness" to help dissipate heat.
Her running the car: she may not have been using them as hard, but I guarantee she was using them more. It is in inherent to ALL newbies. They ALL overcook the brakes at their first 1-2 track events before they understand what the car can do (guessing this was her 1st or 2nd track event) unless of course they have some AutoX experience where somebody taught them threshhold braking.
I'll be at Fontucky for the DE on the 15th. Track me down. I'll help you bleed the brakes and show you the fastest way to get ALL the fluid out of the calipers.
B
Engine Builds, Transmission Builds, Engine Conversions, Suspension Installs, Suspension Tuning, Driver Coaching, Data Acquisition, Video, SCCA/PCA/POC/NASA/GRAND AM/ALMS.
We have worked with amateur and professional drivers for over 26 years. In house machinist, In house fabrication. Our cars, our parts, our engines, our transmission's run nationwide at events every weekend. We work side by side with industry names developing parts.
Brad Roberts is offline   Reply With Quote
