Old 06-10-2009, 07:29 AM   #3
Brad Roberts
Brad Roberts's Avatar
Pull the slave. One bolt holds it in. The head of the bolt is 13mm. After removing the bolt, use a small prybar just behind the area where you removed the bolt. Pry the slave forward 2-3mm's and pull it towards you and BACK.. it will come out of the tranny. Clean and grease the end of the pushrod. I use brake clean and a high temp BOAT TRAILER wheel bearing grease. The boat grease is designed for extreme temp change and happens to be WATER proof (think: pulling a heavy boat down the freeway and then submerging the trailer into a cold lake) It works well
I'll snap a picture for you this morning.
B
Engine Builds, Transmission Builds, Engine Conversions, Suspension Installs, Suspension Tuning, Driver Coaching, Data Acquisition, Video, SCCA/PCA/POC/NASA/GRAND AM/ALMS.
We have worked with amateur and professional drivers for over 26 years. In house machinist, In house fabrication. Our cars, our parts, our engines, our transmission's run nationwide at events every weekend. We work side by side with industry names developing parts.
Brad Roberts is offline   Reply With Quote
