Old 06-10-2009, 06:45 AM   #2
JFP in PA
Originally Posted by Steve Tinker
For the last two months I have noticed that my clutch has a dose of severe squeaking every time I depress the clutch pedal. The noise is coming fron the slave cylinder above the gearbox - I have bled the system (a pita) but to no avail. On previous cars, a squeaking clutch was normally cured by greasing the thrust rod pushing on the clutch actuating arm, but on the Boxster the arm is not visible for lubricating.
Am I missing something or do I have a problem...?
The noise may be coming from the pivot point where the slave contacts the throwout fork. If that is the case, you need to pull the slave and lightly lube the fork end with a small amount of high temp grease (usually made for brake applications). If that does not cure it, the fork may be going, which requires pulling the gearbox to gain access..............
