Old 06-10-2009, 06:35 AM   #11
JFP in PA
Originally Posted by Frodo
Two other questions come to mind: (1) Is it a given that when you flush the brakes you should flush the clutch as well? (as the Pedro's Garage article seems to suggest.) And, (2) Is 1 L of brake fluid definitely enough?
Yes to both questions. Be sure the clutch pedal is held to the floor when bleeding the clutch. If you are careful, one liter will do the job; and do not over pressure the Motive bleeder, 10-15 PSIG is fine, but going too high can lead to issues......
