Old 06-08-2009, 10:11 AM   #1
Lucky
$1000 is a bit tight, if that includes the cost of alignment.
If you can't stretch to $1500-$2000, then about the only thing you can do for <$1000 is top-flight sways and drop-links. They will make a big difference, so don't discount this as a good starting point.
If you can stretch the budget a bit, then I'd recommend RoW M030 suspension kit + aftermarket drop links. This will cost you closer to $1500 all-in if you do your own wrenching but pay for an alignment.
Good luck...
-- John
'00 Boxster S
'86 911 Carrera Coupe (Sold)
Lucky is offline   Reply With Quote
