Originally Posted by grubby66
Hi.
i need help with a 2003 boxster s. the car suddenly started cutting out after a battery change a feeks ago, it made it 250 miles before it started playing up. i have checked it for trouble codes and nothing found, i have changed the dme and the starter relays, checked 9 earth points, been through as much wiring as possible and found nothing, checked the alarm module for water ingress and no faults there.
When the car stalls, are the electonics in the car (radio, hvac fan, etc) still on, or do they shut off also?
If its just the engine shutting off, I would recommend disconnecting the MAF sensor, and driving around with it off, to see if that might be the cause somehow.
If everything dies, check the connections on the alternator.
Loosen them, retighten them, and add some die-electric grease to protect them.
BC.
