Old 05-29-2009, 07:36 AM   #13
Topless
Track rat
Topless's Avatar
Originally Posted by drem914
topless, how was ez-lube to change your oil? Don't know if i trust them to do the right thing or not. Have you had them do it several times for you and have you had any problems?
They do lots of German cars so they are already in the ballpark. I supply the oil, filter and crush ring $80ish. I bring a DIY checklist which lists specialty tools, explains the need for long drain time, and has torque settings, and the need to only refill with 8.5qts today. I will top off tomorrow. I spend two minutes with the tech and explain that an oil change on a Boxster is easy but it is a little different, and gently walk him through the list. He understood, did nice work, and charged $20 labor.
