Engine access is horrible with the GAHH tops. The original plastic window would fold in half as the last bow came up into service position, whereas the new glass top can't fold in half obviously, so it just comes up a fraction of the way the plastic top used to. Literally there is barely enough clearance to remove and insert the engine cover and "pizza oven." Access to the air filter is doable, as it servicing the power steering fluid, but it is not much for actually working on the motor from the top.
Boxster S
