Investigated further myself and got it working !!!
The release handle anchor socket in the windshield has two microswitches, the first lowers the windows an inch and the second sends power to the relay to signal that the handle is open and that power can be sent to the motor to lower the roof.
If you pop out the two red lenses either side of the handle you gain access to two T25 star screws. Remove them and the socket/interior light assembly drops down. I disconnected the pin connector to the microswitches, cleaned the pins and the sockets and everything is working fine. real piece of luck because the only reason I had another go is because the relay unit which i thought was faulty is on 3 months delay from germany !!
