			The tie rod has a ball joint on the outside end, connecting to the bearing housing/brake mounting assembly. On the inside end, it threads into the arm that connects it to the steering gearing, and then goes through to the other wheel. The inside threaded part has a locknut, which may be loose. Hope that helps.
