This might work .I had to something similiar .Cut head off bolt with dremel cut off disc -or if no acess grind it off .Second person with vacum is a big help .
File end of bolt to enable threading nut on .Use socket as a spacer between nut and header .Tighten nut until brass fitting snaps-and it will .
Travel at your own risk -but it worked for me .
Dave
