Old 05-19-2009, 04:40 PM   #1
LowFlyR
Originally Posted by Kirk
I concur with Blue-S to an extent. The person doing the alignment obviously sacrificed toe in the rear to get the camber down to something more reasonable. I think this was a poor choice. Negative camber will have an impact on tire wear, but will not negatively impact handling. In fact, more negative camber is very desireable with racing. Too much toe on the other hand could make your handling worse. I do my own alignments with my lowered cars (coil over systems). I pretty much adjust the rear to get the toe perfect and then just let the camber fall where it does (as long as it's balanced, no more than 0.1 degree difference side to side). I don't really care if I have 2.5 to 3.0 degrees of negative camber. I can buy more tires and enjoy the good handling for now.
If you want it perfect for a street setup, then you'll probably need adjustable toe arms (I like Tarett) to get both the camber and toe right.
The front looks fine to me. You can't really get less negative camber than -1 with lowering springs.
Kirk
Thanks. Tarett price is a little steep for me right now. Do you know anybody else that makes them?
Jake
http://www.jazmine.com/images/avatar.jpg
My FB has lots of pics
01 Speed Yellow Boxster S
- Tip
- PSE
- C4S Cluster with new style OBC
- 18" with 7mm rear spacers
- Litronics
- Fully de-ambered
- LED taillights
- Aluminium Pedals
- Integrated Garage Door Opener
- 986 emblem
- Yellow brake calipers with Brembo stickers
- Yellow center console
- Aerokit II wing & trunklid
- Eibach Pro springs
In memoriam: Black 935 Street
LowFlyR is offline   Reply With Quote
