Old 05-18-2009, 11:24 AM   #5
Bladecutter
Originally Posted by paulv
Did either of you guys hone out the piston cylinders, or is that a lost art? The last time I rebuilt a caliper was about 25 yrs ago!! Thx.
Regards,
paul...
Honing brake calipers is only needed if there was corrosion inside the cylinder bore.
This of course only happens if the brakes are neglected for a long time, the brake fluid absorbs alot of water, and then rust forms in the calipers.
Since I believe the calipers are made of solid aluminum, the need shouldn't be as great for honing the cylinder bores, as aluminum rusts entirely differently than a steel caliper.
BC.
Its not how fast you go, or how expensive your toys are.
Its all about how big your smile is at the end of the day that truly matters.
'98 Silver Boxster, '08 Ducati 848, '89 Honda Hawk GT, '89 Honda Pacific Coast
Bladecutter is offline   Reply With Quote
