Originally Posted by gdalby
Well, after getting the numbers back from the shop I originally took the car to, I decided to go get a second opinion. The first shop was suggesting either putting a used transmission in the car, or having a gear box from California shipped in that supposedly "solved" this issue. I thought it funny that the shop could make a decision on what needed to be fixed with the car without even taking the transmission out and resorting to a $6500 fix. Thus, I contacted a friend of my father's who owns several Aamco Transmission shops in the area and took it to him.
This morning he informed me he had priced out the parts it would take to repair the second gear and also that Porsche has released an upgrade for this second gear problem, something the last shop had mentioned nothing about. His estimate is about $3500 to rebuild the second gear and all affected parts. Luckily, my warranty will cover up to $2500 for it, so I wont be out that much.
Does anyone know anything about this upgrade for the second gear from Porsche? I find it very odd that the first shop mentioned nothing about it. In any case, I'm happy that the car is finally getting towards a solution and I should be getting my car back by Monday or Tuesday. I think I might have forgotten how to drive a clutch!
I just went through this ordeal so PM me if you have specific questions. Porsche has made an update to the gearbox & when yours is rebuilt, it should be slightly reinforced from the original unit. I had it done. Seriously, it's an extra sleeve, but it apparently makes a huge difference.
I would probably keep looking or as other members suggest, try Gbox. At least give them a call. My warranty company also wanted me to go to AAMCO for the repair. Even at a Porsche dealership or Porsche specialist, there's usually only 1 guy on the premises who works on transmissions. I do not have faith in asking AAMCO to rebuild your transmission. Good luck!
