Old 05-10-2009, 11:38 AM   #3
JFP in PA
Originally Posted by jhandy
Also I drilled a 1/2 inch hole through the plastic cover so I would not have to remove the cover just to remove the drain plug.
Sorry, but putting a hole is the belly pan is somewhat of a waste of time, as you still need to pull it to disconnect the foward hoses and drain the radiatiors as well. No sense in doing half the job once the car is in the air................
