Old 05-10-2009, 11:37 AM   #2
Jaxonalden
Jaxonalden's Avatar
Originally Posted by jhandy
Hi,
I was washing the car today and got to thinking about my EVO "cold" air intake.
If you look at it, (1) I am sure it is not cold because it draws air in from the engine compartment.
So, I was thinking...........remove the filter, and fab a pipe that continued on in to the space outside the engine compartment between the intake vent fins and the body. Would I have to move the MAF sensor?
Is this possiable? can you find generic piping and plumb it out of the compartment?
OR (2) I was thinking of making a plastic cover to cover the top of the standard EVO setup and I could more or less seal the box so that it only draw air from outside.
If the install was not such a Pain in the A** I would replace the stock box.
Just thinking
1. EVO intakes do not draw air from the engine compartment.
2. EVO intakes come with a compartment panel that the filter sets in that is completely sealed off for the engine compartment.
Where did you get your EVO intake, second hand? If you would have bought it from a distributor you would see the panel and instructions for installation. http://jbkperformance.com/evolution_motorsports/evolution_motorsports_high_flow_intake/g-53034.aspx
