Sounds like you didn't get all the old oil out. The car has to be perfectly level in order to do so. I just jack up one side then slide under there, then lower it down and let it drain. Much easier than setting it up on jack stands. Maximun capacity is 9.25 quarts, but 9 is just fine. If it's well over the max mark on the dipstick, I would pull the plug and drain some out before you drive it anymore. Make sure you check the stick when the engine is stone cold to get the most accurate reading.
