Thread: Idle at start
Old 05-04-2009, 11:35 AM   #1
Rekogniz1
Idle at start
I am a new boxster owner and have a few questions: It is a 2002 Boster Base model. When it is first started it seems to idle a little rough for about 10 seconds and then idles just fine after a while. Next thing is when AC is activated the idle drops also and it will run rough for a bit and then goes away. Is this normal for a Boxster? the second thing is when first started it sounds like I have a small exhaust manifold leak that goes away after it gets to temp. Should either of these be a concern or are these normal?
Rekogniz1 is offline   Reply With Quote
