Why spend the money to install a 20 yr old engine into a boxster when you can make a much easier install with a 3.2 boxster engine?
Nothing will match up with the 911 engine, but anything is possible I suppose. I leave the solution to more knowledgeable bodies, but I would imagine obstacles on the mounts, ecu, transmission mating, throttle, air box.
Cooling system would be drastically different.
It would be interesting for sure. Post progress
