Old 05-01-2009, 05:41 PM   #12
husker boxster
husker boxster's Avatar
The modification comes into play with the e-brake cable. You'll have to pin it out of the way, which is easier said than done. The suspension arm never holds the zip tie for long - it just slides down the arm and the cable moves back to its rightful place. Never did figure out a good way to do this on my 01S.
Also, no wheel weights on the inside rim of the wheel - they'll clip the suspension arm. Have to use the glue on kind inside the rim.
1989 928 S4 5 spd - black
