Old 05-01-2009, 07:35 AM   #10
renzop
Another solution is to get rid of your wheel bolts entirely and replace them with wheel studs and open end nuts. The you can use sandwhich style spacers or not and have the same setup. Studs make changing tires much easier as you have something to hang the wheel on. Studs and nuts are also lighter than bolts and its are easier and cheaper to replace the nuts if you lose one. Check out rennline.com. That's where I got my set.
renzop is offline   Reply With Quote
