Old 04-29-2009, 09:32 AM   #11
Boxtaboy
07 Carrera S Cab
Boxtaboy's Avatar
Originally Posted by rick3000
Great Job!
I had heard the tops where interchangeable, but you are the first person I have heard of who has actually done this. When my plastic window breaks I will definately be doing this.
Do you know if it will work on a '99?
And what relays do you need to replace, do you have the part numbers?
Thanks!
Btw, just to clarify, in late 1999, Porsche made the changes to the top relay and top transmissions/microswitches, so it is possible (if your 99 is a late 99 model) that you can just drop in a 2003/2004 top without any modifications. Take a look at this picture....this is a picture of the top motor which is right near the third brake light in the trunk. Just open your top part way, and you'll be able to see this top motor unit. If you have that lever coming out of the top motor, then you will have to modify your relay and transmission microswitches, but if you don't have that lever sticking out, you have the updated parts, and you will not need to make any changes...just pop in the new top and you're good to go!
